On my way home today, the clutch paddle went to floor and wouldn't bounce back when I pull into the gas station near my house. I pumped it several times and it came up just a little but enough to put into the gears to get home.
When I looked under the hood, there was no clutch fluid in the reservoir! I am pretty sure it was OK last week when I checked. I refilled the reservoir and pumped the clutch paddle the way I bleed to brake. After refilling the reservoir a couple of times, I regained a firm paddle. I end up refilled the reservoir 4 times all together. I noticed a puddle on the drive way under the passenger side. I am not sure it was the fluid from the clutch. It could not be the water from the a/c, since it did not dried up after a couple hours. There is no leak from anything that I can see under the hood. Now the car actually shifts a little better than before.
My question is that do I have a major clutch problem? Do I need to have it looked at by someone before the next S2K event?
Thanks,
Gab
