Single Row Crank Pulley 1.6
		Posted this to the big board but thought I would check here as well
The motor in the 90 that I built for STS2 had a two piece crank pulley. (1-alt/WP + 1 AC)  I replaced it with an OEM double pulley but have been wondering about using the single alt/WP as a low cost way to reduce rotating mass.  Shop manual does not show a single row crank pulley so I assume that it came from another car (323?).  Diameter and mounting holes including keyway are identical to the double row.  Can't find any reference to this in the archives and I know that Andy in his build cut the 2nd pulley off an aftermarket underdrive pulley.  Is there any hazard in running just the alt/WP pulley?
Thanks
Steve
