I have a 1990 miata and it wont start. It was running and now it won't. I have great compression and great spark, it will crank all day. (till it kills the battery at least)
I thought it was the fuel pump because when I turn the key to the on posistion it does not engage the fuel pump. When I turn the key to the crank posistion it does engege the fuel pump but still won't start. ( I bought a new fuel pump and it responded the same so I took it back) I've been told that is normal for the fuel pump to only start pumping while cranking. Is that correct? I went and bought a new CPU and it made no differance and also a new thing that sets on top of the air cleaner housing, it made no differance. Several people have told me it sounds like the cam senser is bad, and the crank sensor is bad. I know the cam sensor is on the back of the head by the fire wall, is there also a crank sensor some where or is the same sensor being called two different things? I don't want to waste any more money gussing. Can I test the cam sensor some how ti make sure its good or bad? Please advise.
[email protected] Thanks
