Car Shuddering
		My car is doing a very bizarre thing and it only does it in two situations.
1) When I leave my parking lot at work I go down a slight incline and turn right onto the street. The car then hesitates, shudders/stutters and then everything turns off and then comes back on. It only happens when the car is cold.
2) When I go over bumps like railroad tracks it does the same thing except the car is now warmed up.
I do not get any codes when this happens.
I am stumped as to what it could be, don't know if it is electrical or some hose that is loose?
Any help would be appreciated!
		Check/clean/tighten the ground wires/connections under the hood.
		Check the battery connections and make sure it is secured.
