I have a 1991 Miata and am having a bit of a brake dillema. When I depress the brake pedal, it will go to the floor. When I pump it repeatedly, it is like it pumps up and I get pedal pressure and feel back. If I let it sit for a minute and press it again, it will go to the floor. I have run the brake booster check in the repair manual and it appears to be working ok. Also, the master reservior had a leak and I switched, but that did not help either. Could the master cylinder be shot completely or could it be something else.
Thanks,
Rob
