I just returned home from having AJ at NTB in Lewisville align my NC.
It drives like a different car.
Thanks AJ, you do great work.
Did you change suspension or wheels/tires before hand or did you just go for alignment? Also what did he charge? I have an NC too with 12,500 miles on stock suspension and 16's with Yokohama Advan A11A's and they seem to track ok but get light and loose in hard curves. Plenty of good tread left on 'em so I'm not rushing into changes.
AJ is the man. What you pay depends on what you need whether it's a 1 time, 1 year, 2 year etc. I would suggest just getting a 1 or 2 year that way in case you hit something or want to make some adjustments later you can go back in. Just go in with your normal setup and he'll check your tire pressures then start the alignment.
So far he's done the S2000 twice, RX-8 once, Elise once, and Miata once all with great results.
I didn't know he charged that way. Guess I'll try the one year depending on how much more it is than a one time. I'll probably have the suspension and wheels done in that time if not sooner.
Just PM AJ for the details.
AJ is "the man"` Please note that he does not own the shop. Please do not forget to leave him a gradtitude! It is way better to have both you and AJ are happy with the work!
Thanks. PM sent.
