For Sale ’99 Supercharged Sport Miata Prepared by TDR
		I really like this car and had hoped to keep it. Insurance is great, parts are cheap, and it is a blast to drive. But I cannot fit in it w/o major cutting on the floor pan. Car is too nice to destroy.
For Sale '99 Sport Miata prepared by Track Dog Racing. Engine replace under '99 thrust bearing issue at around 42,000 miles by Mazda, the car currently has 80,000 miles. The car currently has 215 HP and 187 ft. lbs of torque running 11 PSI. This is a great reliable power level that is not hard on the drive train. Club Sport Miata has the Torsen Limited Slip rear end, roll up windows and manual door locks, front and rear spoilers. Car now has Bilstein PSS9 adjustable coil over with 400 lb front springs and 343 lb rear springs.  This is a great street and occasional track setup.  The current list of parts is long and listed below.
ENGINE PARTS LIST
Stock internals with 39K miles
TDR/Moss MP62 Supercharger
TDR Air Filter upgrade kit
TDR Belt Tensioner upgrade kit
Custom Injectors
TDR Intercooler
TDR Oil Catch Can
Powercard Fuel management
JR Timing management
TDR Patch Harness for fuel/timing
ACT Extreme Clutch, stock flywheel
SS braided clutch line
Koyo Polished Radiator
Dual Fan wiring setup
TDR Crinkle Red valve cover
Modified belly pan
Dual hydraulic hood lifts
EXHAUST PARTS LIST
Jackson Racing header
Goodwin Racing 2 1/2" midpipe
Racing Beat muffler
TDR Header Heat Shield
SUSPENSION PARTS LIST
Bilstein PSS9 Coil-Over setup with 400 lb Front and 343 lb Rear, adjustable dampening control.  Ride height set at approx. 12 3/8" front and 12 5/8" rear.
Upgraded sway bars front and rear
Hawk HP Plus brake pads front and rear
SS braided brake line
MazdaSpeed engine motor mounts
TDR-PPF Power frame and differential stiffener kit
Factory fog light bezels opened for more direct air cooling to the brakes
OTHER COMPONETS
TDR 3 gauge kit including Boost, AFR and Water Temperature
TDR Air Splitter
Auto Power Roll Bar, works with hard top
Rota 15X7 Slipstream and Kosei K1-TS gunmetal gray.
The Silver ’99 has excellent interior, exterior, convertible top, and excellent hardtop. You are welcome to do a VIN check, JM1NB3532X0124009.  Engine bay is spotless and there are no oil leaks. Transmission and rear end fluids were replaced with Red Line about 5000 miles ago.
PERFORMANCE
Track tested, the car is dialed in ready to go play. On the street the suspension dampening is compliant meaning it rebounds quickly. Everyone who has ridden in this car loves the handling and performance. With DOT race tires this car is hard to beat.
PRICING
The Sport without any of these upgrades is valued at $8500. When added up, there is right at $12,000 in performance upgrades, not including any of our labor. Here is a car that is complete and tested by TDR to meet and exceed anyone’s Need-for-Speed. Car is for sale for $15,800, now $14,000
http://www.youtube.com/watch?v=JXpS8Zwz3g0
http://www.autoxforum.com/gallery/al...28Small%29.JPG
http://www.autoxforum.com/gallery/al...28Small%29.JPGhttp://www.autoxforum.com/gallery/al...28Small%29.JPG
