Lowered Price Autocross STS2 Miata For Sale
Price now lowered to $4,800
1993 Miata STS2
Pix available, or see in person in Grapevine
Car is not currently registered for the street, but could be licensed and inspected.
Build one just like it for over $7,000 parts prices (not including some parts or any installing, aligning, tuning, misc. supplies) plus donor car price of around $3000.
Total of $10,000+ not including lots of labor and sorting.
Priced to sell at only $5,500, or half price. Ready to run.
White with decent tan top, black interior. Northern car. Not a beauty queen but healthy drive train and fast.
Former Craig Mankiewicz car. 2006 STS2L National Champ car.
Unknown mileage on engine, but leak down and compression test, plus dyno tune prove it is healthy. Car has VLSD that is as good as those get.
15” x 7.5” Rota Slipstreams with shaved Kuhmo MX. new $500 for wheels, $150 used tire value.
From Craig’s build, stuff that is now two seasons old:
• new Racing Beat header new $450
• new Mazda cat new $130
• new Borla stainless cat back exhaust new $450
• all poly suspension bushings new $400 from MazdaSpeed
• new Mazda clutch/pressure plate new $250
• new clutch master and slave cylinders new $125
• new brake master cylinder new $100
• all new suspension bolts including new style eccentric adjusting bolts new $45 just for eccentric bolts
• new Unorthodox Racing crank pulley new $250
• new plug wires new $75
Improvements and maintenance in 2007 (only run three times in 2008):
• new timing belt/water pump/cam oil seals/cam tensioners/fan belts/plugs $500 parts and labor
• dyno tune at Applied Racing Technology $150
• corner weighting and alignment by Spec Miata specialist to my autocross settings, $200
• synthetic fluids new $30
• Jet reprogrammed ECU $400
• revalved double adjustable short yellow Konis with new coil overs & springs new over $1000 for Konis, $400 for coil over/springs
• One Ultrashield Rally seat (17”) on factory slider and ballasted to 25#
• new front hubs w/ longer studs new $275
• new rear calipers new $200
• new brake rotors/pads new $150 pads, $60 rotors
• new Mazda radiator new $125
• new coolant hoses (all 8) new $75
• new SP Induction Systems SPX2 intake new $200, cone filter $50
• new small battery new $40
• new MazdaSpeed HD front swaybar mounting brackets new $175
Other stuff goes with the car, including two spare front sway bars, rear bar, spare power steering rack/pump, black soft top in good shape ready to bolt on, set of OEM 14” wheels with junk tires.
Willing to sell in different configurations, can do any or all of following:
• no competition wheels/tires, only OEM 14” wheels with junk tires;
• can substitute Kosei K1-TS 15” x 7” wheels instead of Rotas.
