Ok, I'm going to try one last time.
I need an injector harness for a 1994 car. The '94 harness I need has the following plugs:
(4) 2-pin injector plugs
(2) 4-pin coil plugs
(1) ground (2 wires going in)
(1) temp sender (1 wire)
(1) other temp sender? Green 2-pin plug
(1) 6-pin connector (to main harness)(orange inside)(only 5 pins used)
(1) 8-pin connector (to main harness)(yellow inside)
Up to this point I've found 2 harness that are different from eachother, and different from what I need. The one I have is damaged and I haven't been able to figure out whats wrong with it. I've checked it for shorts and bad connections and haven't turned up anything. I really need this harness. I'm seriously so frustrated with this that I'm about to give up on the car over it.
If you have the harness described above, or know somebody who might, please let me know.
Thanks
John
