FS: Boost, Oil Temp and AFR Gauges
		52mm gauges. Amber/red color. All electronic.
As far as I can tell, these SAGA 3.0SR (AKA V3) gauges aren't available anymore. Looks like all that's out there is V2 and V5.
These have peak/hold, startup ceremony with the needle dance, user-programmable warning function with beep and flash, gauge visors, gauge stands.
This is what they look like.
http://www.steveandlee.com/galleries...s/air_fuel.JPG
http://www.steveandlee.com/galleries...s/oil_temp.JPG
Some "official" features:
• High precision full angle sweep stepper motor
• Electronic sensors accurate to +/- 1%
• On/off self diagnostic sweep on startup
• Built-in warning light
• 52mm gauge body
• Lightweight high heat dissipation body
• Full aluminium body construction
• Set warning values using the gauge
• Audible & Visual warnings can be set
• Optional Turbo timer module can be fitted to Turbo gauge
• Optional fan controller module can be fitted to Water gauge
• Optional external warning/shift light can be fitted to any gauge
• Turbo, Oil Pressure & Rev Counter gauges can be calibrated exactly to your engine
• Peak light built into gauge
• Peak value record/playback functions
Couldn't find a pic of the Boost/vacuum gauge. It's in PSI and goes from -14 to 29psi. AFR gauge is narrowband.
Selling these because I got some other gauges that I like better. They work fine.
All sensors and wiring harnesses are included. Some wires have been extended and are labeled appropriately for easy identification. Installation instructions are included.
Asking $175 for all 3.
They're still in the car. Taking them out this weekend. Please email [email protected] if you're interested. I don't check PM's here often.
Thanks.
