went to work this morning and all was fine car shifted with no problem. Came out this afternoon and pedal went to floor . Was able to get from reverse to low and could shift into all gears while going . Stopped and then would not shift pedal real low to floor
Got home and checked fluid level and then looked at slave cylinder . When working the clutch pedal the slave would work the fork back and forth
Think maybe pressure plate forks broke
Any ideas before having one put in
Have a guy for roughly 350.00 furnish clutch,pressure plate,throw out bearing ,pilot bearing and face flywheel and guarntee 1 year no limit on mileage
Thought this was cheap enough
