Weird alternator bolt issue.
		Last year about this time my alternator belt started squealing a bit. I chalked it up to cold weather but when I went to tighten the belt I found out that what had really happened is that the bottom mounting/pivot bolt had backed its way out. Fortunately, there's (what looks to be) an intake manifold support bracket behind the bolt that stopped it from backing all the way out. But the alternator was loose enough that you could wiggle it around manually. No big deal - it was a 2 minute fix to get the bolt back in and everything torqued down.
Yesterday the belt started squealing uncontrollably again. This time, older and wiser, I checked it and - yup - that dang bolt backed out again. But this time it wouldn't thread back in. I can push it all the way in until the bolt head seats. No threads.
I can see the threaded hole on the near side of the alternator and I don't see sheared-off bolt threads in the hole. So I'm at least hopeful that I don't have to re-tap anything. But it just seems very strange that such a low-stress bolt would A) back out all the way on its own and B) lose its threads.
Did this ever happen to anyone else?
