Came out of a 99 Camaro Z28 hit in the front. No damage to the block, heads or transmission. The edge of the throttle body is broken, as is the idler pulley. The motor was sat on a bolt or nut and the bottom of the oil pan is cracked, all pieces are there, a good TIG welder could handle the repair. Wiring harness and computer included. $2700, $2500 if you let me drive your Miata after you install this.......
