Out of room... 1.6L parts for sale
		OK,
I have a bunch of parts for sale... Got to clean out some room in the garage.
1 parts block w/bad short nose crank. With oil pan and pump. It's ugly. Comes on a furniture dolly to make it easier to move around. - $20
1 complete 1.6L engine. Low oil pressure issues (30 cold, 8 to 10 hot idle) but does run. Head has been replaced. It's complete w/alternator. Comes on a furniture dolly too. - $125 (I know this one had a new timing belt installed but I forget if it had a new water pump put in too...) PARTIALLY PAID FOR
10 head bolts (used) - $5 for all
1 1.6L Intake assembly - Missing IAC valve - $20  (price lowered)
1 1.6L short nose crank (oiled up & sealed in a plastic bag for the past 2 years) - in good shape. - $100
1 1.6L big nose crank (some surface rust) and baffle - Needs checking for trueness. $50
1 Engine Stand - new in the box. ($89.99 from O'Reilly) - $40 SOLD!
1 Clutch Slave Rebuild Kit - new in the box. $15
1 driver, 1 passenger Black armrest - long type. - $5 pair
1 set soft top latches - $10 ON HOLD
1 set hard top (front) latches (Sorry, no side latches!) - $10
1 set top latch recepticles from windshield header - $5
1 AFM - $30 SOLD
I have a few exhaust studs, new from Mazda, and some other miscellaneous pieces that I'll add to the list later.
It's all sold as-is... Cash talks... PayPal accepted... I have an engine hoist here to help with loading the heavy stuff.
		Need Airflow meter for 1.6L engine
		I blew it and pulled the plug out and need to replace the airflow meter. Do you have one available?
