Power Window Repaired with Manual Winder
		Hey All,
Just wanted to pass along a bit of info.  Not sure if anyone else has done this or not.
The power window on the driver's side stopped working and finally 1 of the 2 cables broke.  I bought a manual winder and took it apart.  The rail and cables are the same for a manual as for a power winder.  I disassembled my power winder and cleaned out the crud and old cables.  I wound the manual cables around the spool and reassembled the power winder.
Before mounting into the door, I tested the power winder and it worked great.  I installed the newly repaired winder into the door, mounted the glass and made a few alignment adjustments and an adjustment on the cable at the winder and this window works I think better than new.
Sorry, I didn't get any images but when the passenger side fails, I am ready with a manual winder and will collect a few images.
