I have a mystery here I'm hoping someone can help me with. I bought a hardtop from a '91 for my '94 and it fits perfectly, however...........
I needed a set of side latch striker plates to install on the car, it had never been fitted for a hardtop and I had to cut the trim panels to accept the striker plates. So far so good. Next I tried to install the plates and the screws were the wrong pitch and would not turn more than 1 revolution before jamming in the factory threaded bracket. It turned out that they were the wrong plates anyway so I ordered a set of OEM plates and screws from GoMiata.
The plates and screws came in, each in it's own factory labeled plastic bag and....the new screws also were the same wrong pitch. All of the screws I have gotten so far will fit in the front latch plates but not in the side latch brackets. It looks like the side latch brackets on the car are a coarser pitch than the screws. I went to Elliot's hardware and looked at every metric screw they had but they all matched the factory screws (and were a lot cheaper BTW). Could they be SAE? Any suggestions?
I suppose I could drill out the threads and put nuts behind the bracket if all else fails.
On another topic: I replaced the front sway bar on my car with a factory 10AE front bar. 3/4" to 7/8". You guys probably know that you have to install adjustable links to put a NB bar on a NA. Trying to stay TCB I bought 4 female hyme(sp?) joints and connected them with the threaded section cut off a grade 8 bolt. They worked great and look cool to boot. $24.00 for the joints and lock nuts from Smiley's racing in Mesquite. Good deals on SA2005 helmets too.
