thermostat for track? remove or 160 degree?
For you guys that run track dedicated cars, do you run thermostats? The last time out on the track, my 1.8 NA was running a little hotter than I prefer (210-215) on about an 80 degree day. I'm taking the reading off of the heater return hose. I'd like to see it no higher than 190 given that it isn't even summer yet. One of the spec miata shops I talked to recommended that I remove the thermostat altogether. Another miata shop recommended that I go with a 160 degree thermostat (I have no idea what is in it now, I assume OEM which I *think* is 192?). I already have a Koyo aluminum radiator. What do you guys run in your normally aspirated track miatas? Is there any drawback to not running a thermostat in a track car? I do drive it to the track and back sometimes.
