this sound like a short to you too?
		since it got cold, my car has been sputtering when rolling from a stop and shifting gears early. like, anywhere below 3k causes a hesitation and actual sputtering that feels and sounds like a misfiring cylinder. it evens out relatively quickly but it is annoying and recently seems to have been getting worse.
now it is more persistent causing near-stall situations when accelerating from a stop. it is especially bad when turning while accelerating. the headlights dim, the car shudders exactly like my 240 did when it had a dying injector.
i always let my car come to normal operating temp before i start driving it, so i know its not a cold-start issue. the issue also manifests after several miles of highway driving. recently i have noticed a gasoline smell beginning to accompany the stuttering.
while cruising on the way home last night, i was maintaining a constant speed of 65 and noticed the tach needle jumping from 3k to 4k repeatedly. there was no change in engine speed, throttle input or anything else that i could tell.
im about to perform a tuneup, this will include new plugs, checking and replacing engine grounds, fuel filter replacement and thats about all i can think of that would be causing the issue directly. other things might be a clogged valve or vacuum hose, maf going out/needing cleaned, a short somewhere causing a hiccup. that seems more unlikely.
the engine is getting up there in mileage, anyone know if this is a really common issue that i am overlooking?
