Verizon FIOS not compatible with Samsung???
		Venting...
Ever since ditching Time Warner/Comcast in favor of Verizon FIOS, I've had some issues with my box. Most days when I come home, the box will not react to the remote and will not turn itself on. The only recourse I have is to turn the box off at the power strip, wait 10 seconds, and flip it back on. Then everything works smoothly.
My other problem is that over 50% of the time when I attempt to DVR a program, the box records only the first 7 or 8 seconds of the show. I cannot tell if this problem is related to the first issue. 7 seconds of Top Gear does not cut it!!
I've called Verizon about this, and they are telling me the problem is my HDMI cable that runs form the box to the TV. Apparently some TV brands (including Samsung), when linked to the box via HDMI, interrupt some signal and cause this issue. I've been told that my only recourse is to remove the HDMI cable and use component cables instead.
1. Anyone else have similar issues with Verizon?
2. Provided that their advice is legit, how much degradation in picture quality and surround sound quality can I expect with component cables instead of HDMI.
Thanks!
