I've got an oil leak that seems to be coming from the top rear of the motor, around the Camshaft position sensor/distributor-ish parts and the rear of the valve cover. Is this common, and or likely to be a valve-cover gasket issue, or should I be looking more in-depth? Since I'm new to Mazda engines, I figured I'd ask for special things to look at before I just go and swap the top gasket and then find out I need to do it again along with other stuff. The valve covers are definitely torque'd down properly. Thoughts or suggestions?
