Cruise control issue...
		OK,
The infamous forum cruise control is in my possession... and it doesn't have the right wiring connector on the back of the #$(&#$ switch.
It looks like the car doesn't have all the wiring harness pieces to make it work. Does anyone here have a 02/03/04/05 with cruise? I'd like to peek under the dash to see how everything connects.
The strange thing is it has the right connectors for the unit under the hood and the right connector for the control computer, but not for the switch.
I need to peek under the hood of someone's car to see the vacuum line hookup and to see what the wiring looks like under the dash.
Anyone?
		What switch do you have?  The one in the wife's '02 is a fog light cruise control combo switch.
I might be able to post some pictures if that would help.
		I need to see the back side of the switch. Also a pic of both the gas pedal assembly and where the vacuum line connects to the intake.
I'm missing parts from the pedal assembly and something isn't right on the back side of the switch. Everything else is fitting OK.
