I've got something knocking in what sounds like the right rear. I thought at first that the right rear rotor was warped because of the intermittent sound it makes but after replacing all four rotors and pads I've still got the knocking noise coming from somewhere back there. I'm leaning towards it being the hub because, unbeknownst to be prior to buying, the car had been wrecked. P/O was pinched between a semi and a K-rail but he failed to mention that, I only found out after browsing the mazdaspeed forum that it had done a number on the right front/rear suspension. Anyway, I've tried taking a few videos to capture the sound but I don't know if it will help. If I turn right, thus taking some of the load off the RR, it will go quiet but as soon as it is back under a normal load it picks back up. I've also noticed that there is what I think is too much lateral(back and fourth) slack in that hub when we had the wheel off but I've yet to compare it to Rotarynerdette's car to know if it's excessive. Do any of you guys and girls know of specific points that I need to check to try and narrow down the culprit or have an idea as to what up?
The video quality isn't great but you can hear what I'm talking about.
At around 25 seconds in I start making little right turns and you can hear the knocking stop and start.
http://i173.photobucket.com/albums/w...h_DSCN0662.jpg
Only vid I could upload to photobucket, the other two are just over their 100MB limit.
