OK, I'm tweaking the camber a bit since the NTB guy in Cedar Hill decided he "wasn't allowed" to do custom alignments (???) after making me wait an hour. The Miata tables I've attached show the bolts are to be turned either clockwise or counter clockwise, and give a general rotation guide on the diagram. If I am turning the camber bolt head (not the lock nut), then CW and CCW will reverse relative to each other as I look at the head of the F & R bolts, since they face away from each other. That would mean that the front wheel adjustments are actually turning the markers in the SAME direction, not opposite as on the rear. Am I reading this correctly?
I'm trying to give some negative camber, since I had none. The rear worked-out fine, and I can visually see the increased negative camber, but I didn't want to finish the front without clarifying this point.
