1995 NA Miata 1.8 liter
I will try and keep this short. My A/C does not work. The fan motor will slowly come up to speed, regardless of the switch setting 1,2,3 or 4 and sometimes it will not come on at all.
Here are the steps I performed to troubleshoot:
1) Removed fan and resistor, checked continuity on the fan, resistor, fan to resistor, fan to HVAC control and checked for 12v power during switch proceedure. All passed
2) Supplied 12v to the fan motor itself, damn thing spun so hard and fast I swear I hovered 4 feet of the ground
3) Checked continuity on the Fan relay (fuse box in engine compartment), all is good
4) Check and replaced AD fuse (fuse block in engine compartment)
5) With engine running, I supplied 12v to compressor wire, and compressor kicked on (no cycling occured, I beleive because I was bypassing some core "managemnt" pieces of the HVAC system), but the compressor did kick on and I could see the clutch actively engage/disengage with each 12v supply
My question, without going to step 6 (pulling the ECM and checking it) should I pull the HVAC control unit out of the dash and clean/check the fan switch?
Or am I missing something here, I believe myself to be a fairly competent mechanic, and I cannot believe that this is a difficult issue. I just think that some part of the system is old (we are coming up on 15 years old) and just needs to be cleaned or replaced.
Any thoughts?
TexasCoder
