Which one fuse is for the horn in the NB? How does it labeled? I must have blown the fuse on my 99! The horn is not working. I put in a air horn from HF. This morning I brake and horn at the same time which must have blown the fuse.
Thanks,
Gab
Thanks,
Gab
There should be a cover on the fuse box showing the layout. Check your other car if that one is missing.
PS
Did you add a relay for the air horn?
Sounds like he did NOT.
Good way to get rear ended as your brake lights are on the same fuse.
When I did mine I tapped off the main cable at the under hood fuse box and put an appropriate sized fuse on it for safety. I used the existing horn wire to trigger the relay to activate the air horns.
I also left the original horn in the car so both go off at the same time. Good thing too as I had to use the horn and brakes hard once when some ::Rant:: tried to occupy the same road space as me. The air hose to from the compressor to the horns popped off and left me with only the stock horn.
After a while they'll bond to the horns and y connector so they won't pop off. You'll want to watch for that problem in the meantime too.
