FS/FT: OE Hardtop, 5-spd, 1.6 flywheel, audio stuffins
Hardtop **SOLD**
Next, '93 5-speed transmission w/ ~100k miles. No shift lever included. Still has the fork and bearing from the last clutch install. Only $100! I can deliver to a Wednesday night gathering if you like.
http://i20.photobucket.com/albums/b2...able/trans.jpg
A used 1.6 OE flywheel **GONE**
And now, how about a little audio gear?
Eclipse 8053 cd player, new in box. This is a dead head (no internal power) with three sets of RCA outs. You can either run the outs as 8V or as 16V-balanced. This is an outstanding SQ head, and it will play nicely with a fully active front stage + sub, or a front/rear/sub setup, depending on application. Tons of tuning ability for any audiophiles out there.
Original retail was between $450 & $550 depending on where you found it. Yours for $275. I even have the original receipt from 11/04 if you want it.
http://i20.photobucket.com/albums/b2...lable/ecd1.jpg
http://i20.photobucket.com/albums/b2...lable/ecd2.jpg
With a nice, shiny headunit like the above, you'll clearly want an amp (or three).
Soundstream Van Gogh VGA400.2 amplifier. This is a 2-channel, is 2-ohm safe and can be bridged to a single channel for sub duty if desired. This unit was used as an in-case display, so it has been out of the box but not installed. One mounting foot is separated from the case, but is included.
Full specs can easily be found online, or I can scan the side of the box for you.
Retail cost was $400-450. Yours for $175.
http://i20.photobucket.com/albums/b2...le/vangogh.jpg
I also have an old JL 12W1 sub in a 2-cube sealed enclosure, 1/2 Farad cap, PG fuse block, and a pair of Fosgate amps (circa '94) hanging around if you need 'em. Inquire for details.
I think that's it for now. Let me know if you have any questions.
