Why does the longacre gauge have a gap where zero should be?
http://www.longacreracing.com/images...ires/50400.jpg
Not accurate below 6 psi?
The needle on my gauge is mid gap. I thought maybe it was adjusting for different atmospheres.
So they can sell you a low pressure gauge?
Extra ink raises manufacturing costs?
Its common to see that in all pressure gauges. The internal tube deflection is not accurate enough to get a valid reading below 5 psi (or maybe it is and they just don't want to take the time to calibrate it to that level of accuracy.........) Thats so they can sell you a low pressure gauge.
I have seen in before in speedometers also, no reading until 5 or 10MPH.
+1 A mechanical gauge is typically most accurate in the middle of it's range, less so in the outer 3rds. So a 60 psi gauge is generally used to measure between 20-40 psi.
Called Longacre. They said the gauge is not calibrated to zero, so you have the varying "zero" start points. Rather the gauge is calibrated for the scale. Not having a zero peg for the needle to hit keeps it from being knocked out of calibration.
It was really that important to you, huh?
I really wanted to know. I thought you did too. Well, screw you!
a few years ago at the Solo Nationals, Madarash's car was handling like crap and he was mid pack
couldn't figure out why during first day runs
overnight, he had a brain fart and checked his tire gauge against someone else's
his was 10psi too high
fixed the pressures and was near the top on the second day
ever since, he and I check our identical $60 Longacre gauges against each other's every few events
want to join the club?
sure, what matters isn't the precise number, but the relative number
does your gauge always read about the same more/less than mine
not whether they are the exact same number
if the difference becomes large from one measurement to the next, there is a problem with one of the gauges
make sense?
Sounds good.
you mean the gauge on the air pump at the gas station isn't spot on?
