I'm running out of ideas guys, and even miataturbo and miata.net haven't given me a solution. I installed a BEGi Shanghai, mspnp, lc-1 wbo2, and installed a new timing belt/waterpump while everything was off.
1. I smell fuel in the spark plugs when cranking and my fuel pump buzzes when on the 'on' position.
2. I have bright headlights and my battery says it has 11.56 volts
3. I have spark on both coils.
4. No fuses are bad from what I've seen and my wires are in the right order.
At first the car sounded like this.
http://img.photobucket.com/albums/v3...h_MVI_1666.jpg
I learned that my timing belt was actually set wrong, and so I repositioned the cam pulleys so the lobes look like this at tdc.
http://www.rivercityroad.com/garage/pics/cams.jpg
This is what's happening after I just put everything back together. This was a gradual thing after a few cranks, it ended up like this. I'm hoping my plugs are fouled somehow because now I'm not getting spark! They aren't even wet : /.
http://img.photobucket.com/albums/v3...h_MVI_1678.jpg
I'm completely out of ideas, because I don't know what else to diagnose. Can a really really misaligned CAS cause a no start, although it shouldn't be off by more than a few degrees. Besides the timing belt job which looks to be right to me, I'm thinking it could be a megasquirt thing also. If anybody have any clue, please help a guy out. If you are running megasquirt/turbo, come take a look at my car and I'll make it worth your while :(.
