Anyone know how to tighten the bolt that bolt the short tube brace to under the driver seat pan? This bolt is loose. It seems bolt to driver seat pan with sheet metal kind of heatshield (? not sure if it is). I do not find the nut inside the cabin under the seat of this bolt. When I turn bolt from under the car, it just keep spining. Anyone know how? Is it normal for these bolts to come loose? The bolts in rear end of the center brace (the spine) are both very loose too, I tighten them to 80lb. By the way I have a 99.
