Extra Valve Cover Gasket Material?
		since my son's car was leaking oil from the front, I started to do some major work tonight. What better way to spend a rainy Fri night, eh?
bought all the necessary components:
Valve cover gasket
cam seals
water pump
timing belt
crankshaft seal
New radiator belts
New accessory belts
Thermostat
Pulled the valve cover and fought some shredded rubber material that didn't exactly look like the gasket. Here is some of it along the exhaust side of the valve cover.
http://i62.photobucket.com/albums/h1...ata/photo1.jpg
Not sure what this is, but since I can see that the oil is leaking from the top down, could I have gotten lucky and only have to change the valve cover gasket?
