Trash inside fender
		You guys probably already took care of this, and forgive a newbie if you have,
but here's a picture of what fell out of my '91 when I replaced the DS front fender.
http://www.pbase.com/jerrykneupper/image/115367671.jpg
I finally got time to loosen the lower part of the PS fender this week-end and an even bigger wad of crap was behind it.
(No picture, so it must not have happened ;) ).
Also, one of the rain rail drain tubes was clogged up with bits of drilled out pop rivits from a previous top replacement.
A length of co-ax cable poked up from the bottom worked well to get the water flowing again.
Jerry
		Using coax cable was a good idea.  I had to dry my trunk last night from all of the rain.
		I remember doing a little cleaning of that fender area on my old '92.  Amazing how much crap gets stuck in there!
I had to use a spoon because all of the junk was wet and a bit stuck against the inner wheel well.  Reminds me I should do that the next time we have a semi-dry weekend.
