I just put a set of these on the front for Hallett and all I can say is WOW!
I had HP+ in the rears and it was a very balanced set up.
The DTC provide significantly more bite over the HP+ I was running up front. Swapping from my car to Rick's with the HP+ I really noticed a difference.
Some observations.
With the DTC you need to learn to modulate the brakes as wheel lock is rather easy to achieve. However these things don't give up. No fading, no initial warm up issues and once you learn how to use them they are simply amazing.
DTCs squeak and dust as much as the HP+ but do not chew up the rotors like many high performance pads.
As good as these pads are, I decided to save them for track use. (They're not cheap) I decided to wear out some HPS pads I had removed a few years ago before Hallett.
Observations on the HPS after running DTC/HP+
They SUCK! I can not induce lock up on dry pavement but they sure are quiet. I'm spoiled but I guess I'll try to use them up. :rolleyes:
