NB O2 Sensor Pig Tail Location
		Anyone know where the pig tail of the first O2 sensor (the one before the CAT) connecting to the main wiring harness? I tried to follow the wire from the bottom of the car. It disappeared on top of the transmission housing.
My situation is that my 99 has a P0421 CEL. The car had CAL emission and was cconverted to Fed by ditching the first CAT with the use of a RB header. I have a new second O2 sensor (the one behind the CAT) and CAT. Bth less than 6 months old. I suspect it is the first O2 sensor that gives me the code. My car has over 140K miles, therefor it is reasonable that the first O2 sensor is dead. By the way, is there is way to test the O2 sensor.
Also, are those two O2 sensor are identical?
Any info. and suggestion are welcomed!
