Dell Mini 10v (upgraded)
		$250
This is the perfect 10v to make into a Hackintosh (I had it hackintoshed and it worked perfectly). Or use it just as a great portable netbook!
This is not the base model 10v you normally see. Specs in bold are upgrades over the stock spec.
Processor: Intel Atom n280 (1.66ghz vs. 1.6ghz, 667mhz bus vs 533mhz bus -- it's faster)
Memory: 2 gig (most come with 1 gig, I installed 2 gig, the max this computer can take)
Hard drive: 160gb 7200 rpm freefall sensor (7200rpm is way faster than the normal drives and it senses a fall and protects your data)
Wireless: Dell 1397 802.11 b/g
Battery: 56wh/6 cell (it lasts longer -- over 4 hours -- and it sticks down a bit making the laptop nicer to use on a desk or table)
Bluetooth: module installed (use a bluetooth mouse, talk to your phone, etc.)
Screen: glossy, version 2 of the 10v screen (1024x600 resolution, no dead pixels, Phillips LCD)
Card reader: built in card reader
OS: fresh install of Windows XP Home (COA on the bottom of the laptop)
Warranty: Under warranty until 11/2010.
This computer worked well for my purposes, but I don't really need it anymore.
