Should I have my RE-11 AX tires heat cycled?
		Brown Santa  delivered my new set of RE-11's AX tires and they're sitting in the garage  waiting to be mounted this weekend.
 Sorry if my question  has already been already answered somewhere.  I looked around online but I'm  still not sure I have an answer to my specific question.
 Some of the articles I found  were old and I'm wondering if they may not be current with the newer tire  compounds available for street tires.  Some of what I read (older  articles?) indicated that only R-compound tires really needed to be heat cycled  and that street tires were a harder compound that didn't need it.  The street  tires only needed a little driving before the first AX to remove the release  compound.
 Other  articles/postings discussed performing heat cycling on a machine vs. some form  of driving to get them up to temp.  Not sure I came away with a definite answer  here either.  seemed like consensus was that there is a benefit and that the  machine provides a controlled environment and better results but at a cost.   There seemed to be many TCB methods of driving on them for the initial heat  cycle but results may vary as to the actual effectiveness.
 So, assuming that I  understood correctly that heat cycling is really more of an R-compound thing.   I've read all the talk about the new street tire compounds and how they're  getting much closer to the stickyness of an R-compound tire.
So finally...  here's my  question...  Is there more of a benefit now to having AX "street tires" heat  cycled on a machine?  I don't mind paying to have it done if there's a real  benefit (and I can find somewhere in the metromess to do it).  Otherwise, if the  benefit isn't worth the cost, what's the preferred TCB method for breaking them  in?
 TIA,
 Keith
