96 Miata turbo with only 62K miles in Austin, TX $9250
		96 Miata with about 62K miles preferred equipment package (LSD, Power steering, Power windows, A/C, Cruise Control) all options are still installed and working. Black with Black top and interior. The car has just passed inspection and is good till 04/2011. Comes with 2 sets of wheels and tires, trailer for taking your gear to the track, hard top with storage rack. The turbo system is a BEGi S4 system with a # 3 intercooler the exhaust is stainless steel from the turbo back with a 3 inch Enthuza system. The fuel injection system has been upgraded with a MSPNP and New 550cc injectors. The transmission has been upgraded to the later 6 speed and a Flying Miata stage 2 clutch.
The driver’s seat has been replaced with a Corbeau Clubman with a 5 point camlock harness. The passenger seat is still stock but with a 6 point camlock harness installed. The original driver’s seat is included.
The hood has some hail damage on it.
Here is a full list of modifications to the car
Turbo system
BEGi S4 kit with GT2860RS with #3 intercooler
MSPNP Stand alone fuel injection computer W/ Mass Air Flow sensor delete
LC-1 with wideband oxygen sensor with G2 gauge
New RX-7 550cc injectors
6 speed transmission
FM stage 2 clutch (The Level 2 is rated for 353 ft/lb)
Enthuza 3 inch stainless steal turbo racer exhaust with resonator
Cooling System
FM oil cooler
BEGi coolant bypass
Godspeed radiator
Dual 12 inch slim fans
Dual fan cooling mod
Suspension and Chassis
FM butterfly brace
FM rear shock mounts (These mounts allow you to lower the car and keep suspension travel)
NB front shock mounts with custom made bushings (These mounts allow you to lower the car and keep suspension travel)
Koni 1150 coil overs with 450 front 300 rear lb/in springs
Racing Beat front sway bar and brace
Racing Beat adjustable rear sway bar
Adjustable sway bar end link
FM Brake bias valve
Hawk HP+ brake pads
Front strut brace
Hidden trailer hitch for the tire trailer with all wiring completed for trailer lights
Wheel and Tires
949 racing light weight lugnuts
White Kosei K1 with 205/50 15 Kuhmo XS (2 of the tires have less then 1K miles on them)
a set of stock wheels and tires
Full set of stock lug nuts
Interior and Safety
Boss Frog Clearview Maxx w/harness bar
Corbeau clubman drivers seat
G-Force 5 point w/pads drivers side
G-Force 6 point w/pads passenger side
320mm steering wheel
NRG 2.0 quick release
NRG low profile hub adapter
Spare parts that will go with the car
1 front wheel bearing / hub
1 rear wheel bearing
3 Belts
Stock radiator
Full stock exhaust with cat.
Tire Trailer with spare and locking storage box
Hardtop with stand
Car cover
Manual boost controller
Set of spark plugs
If you have any other question just email me or call (512) 751-9653
I will sell the hardtop and stand or the trailer and hitch separately for the right offer.
The link for the hardtop is below
http://austin.craigslist.org/pts/1731353187.html
http://www.bcwolff.com%5Ccars%5CTurbo%5C121_3117-t.jpgLinks to pics below
http://www.bcwolff.com%5Ccars%5CTurbo%5C121_3115-t.jpg http://www.bcwolff.com/cars/Turbo/121_3117-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3118-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3119-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3120-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3114-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3115-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3116-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3121-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3113-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3105-t.jpg
  http://www.bcwolff.com/cars/Turbo/121_3106-t.jpg
http://www.bcwolff.com%5Ccars%5CTurbo%5C121_3121-t.jpg
http://www.bcwolff.com%5Ccars%5CTurbo%5C121_3118-t.jpg
http://www.bcwolff.com%5Ccars%5CTurbo%5C121_3105-t.jpg
http://www.bcwolff.com%5Ccars%5CTurbo%5C121_3113-t.jpg
