My front bearing are beginning to growl when I turn. 114,500 miles on the odometer.
Mazdaspeed has two hubs listed for the '94.
B01A-33-061 Hub, wheel
NA01-33-04X Hub, wheel
Which should I get? Should I reuse the old nuts?
TIA
TIA
One of them I believe is for ABS I'll see if I can find my receipts.
Oh wait I went RockAuto for my Hub! More here -> http://www.dfwmiata.com/showthread.p...=wheel+bearing
If you go that route, here is a valid Rock Auto discount code:
35201831761819 expires August 29th , 2010.
Just paste the code (the code only, nothing else) into the referral block, and you'll get a 5% discount
Yup I suggest rock auto also. One of those part numbers you listed will be for ABS. Surprisingly the ABS hub is cheaper for some reason. Still haven't figured that one out yet lol.
But you can get the Timken bearing hub from Rock Auto for the same price that Autozone charges for their "duralast" brand hub.
not supposed to reuse the axle nut per the shop manual
