shift knob info needed
		anyone know the size/thread  of the shifter where the knob screws on?
will likely have to destroy existing one to get it off
and looking for a replacement -- want something similar shaped to this
http://www.summitracing.com/parts/CAL-188402/?rtype=10
and not as big as a tee handle
but, the Summit one is shiny aluminum so it will get hot in the sun
anyone know of a leather covered or delrin one that might be in the shape I'm looking for?
		Miata knobs should be threaded as M10 x 1.25 if I recall correctly.
No idea where to find a mushroom-style knob like the one you linked.  Sorry.
		Look into the OEM Mitsubishi knobs from the Lancer or Evo, I think from the 2009 or 2010 model, not sure. You can get them at sub Voodoo prices on Ebay.
http://www.3sx.com/store/catalog/sto...er-10-500l.jpg
It's ball shaped, but it's the closest to what you're looking for that I've seen.
Check my sig, I have the white stitch version, from the Ralliart Lancer. Only problem with mine is the Ralliart is manumatic so the threads weren't deep enough, I had to drill and tap them. I believe Juxt3r is correct on the thread pitch, that's what I used to tap them.
Knob is plastic under the leather so it's lighter than stock, but I don't mind the feel.
		I'm using a 8ball that I drilled out years ago , I have a piece of fuel hose in the hole and screwed it onto the threads.  The thread is the same as my wrangler I recently sold so I swapped the shift knobs.  I'd get a pic of it but my Na is at Rouge's getting some work done.
		http://prostores3.carrierzone.com/se...t?sfs=41470362
I use these people above.  I've got a black pearlescant knob I got from them with the 5 speed pattern cut in the top and really like it.  Dosen't soak up a lot of heat either stays pretty cool.
Just give the lady a call and she can get pretty much anything made for ya.
		http://clubroadster.net/vb_forum/showthread.php?t=30292
That is what I have installed... Direct fit, Leather, and 14 oz. not sure if that is what you meant by not as t-shaped....
http://img651.imageshack.us/img651/1159/14ozknob2p.jpg
		it is a bit taller than stock, which was a BIG plus for me. It is a more comfortable position.
Sorry, the club roadster ebay link no longer works. Here is a current link to the knob
Seller-- brucetitusautogroup
http://motors.shop.ebay.com/brucetit...911.m270.l1313
