SCCA Solo Fastrack Posted
		Link
Interesting changes proposed including:
Delete 3.3.3.A.3 (Rule book requirement for Annual Tech).
- Change 7.9.1 to read as follows:
“A clearly-visible line around its base will mark the location of each pylon. The inner edge of the line will be used to describe the outer edge of the pylon base as accurately as possible and this inner edge will be the penalty limit. If the pylon is upset or totally displaced outside the penalty limit, two seconds will be assessed. At Regional events, local methods for locating pylons may be used...."
(Street Touring)...The SEB and STAC are considering whether the treadwear rating minimum in 14.3 should be 180 or 140. Discussions are ongoing and member input regarding this aspect is requested....
