Crazy oil pressure 92 GMC
I'm getting my dad's old 92 GMC Sierra back on the road again and I've got a weird issue with the oil pressure gauge. When first started and while cold, oil pressure pegs the high side, way past the 80psi mark, and does so every time when accelerating, at least until it warms up. I'm hoping it's a gitchy gauge, especially since it seems to have a couple of other electrical gremlins going on as well, plus I've found the same problem with older GMC's on the net.
To determine if it's the gauge or not, can I pick up a cheap one at AZ and connect it to the sender unit? Or if it is a defective sender unit will I still get the same problem? I haven't even found it yet, it's supposed to be at the back of the engine (5.0 aka 305) and it's tighter than the Miata back there. Any ideas or input appreciated.
