1.6 litre timing torque plate adapters
		As another idea i'm also working on a mounting plate that you can use to keep the crankshaft
from turning during the timing belt change on 90-93 model 1.6 litre engines
My machine shop cnc man is working on the pattern . I have detailed photos of how this is used.
It mounts to the hub in back of the harmonic ballancer. 4 #10 grade 10.9 bolts are included.
The other side of the plate mounts where the pivot bolt on the A/C unit is. Just loosen and remove
this bolt and attach the plate with motor at tdc#1 cyl. Then taking out the crank bolt or installing it
is a breeze. Keeps motor locked in position during timing belt change.
They will be $10 and that includes the #10 hardware and shipping to lower 48 states.
The first run will be 12 units...
Miata_B_racing
