FS: Mitsubishi WD 65732 65" DLP TV ($600)
		My wife wanted this one a couple years ago.  Now she wants something smaller.  Women.  :punchout:
This TV is big.  Well, not like big like your parent's CRT TV that they won't get rid of, but I mean the screen is huge :)
It's on it's second bulb and the picture is still sharp.  Sharper than it came from the factory actually since I took apart the light box and cleaned the funk off the lenses (a common issue in the Mitsu DLPs).  This has a 6 color wheel so the colors are better than the older DLPs.
It has two HDMI inputs, 1DVI input, cable card inputs (if you can even get TW or Verizon to give you a cable card), component, etc.  It has a QAM as well as OTA HD tuners.  Remote works fine and really hasn't been used (since I use a harmony for everything).
The TV is in Frisco and I'll help you load it up (tape up cardboard to the front, etc. to protect the screen), but I have no way to deliver it (it definitely won't fit in the Miata).
I'll rent a truck from Lowes on your dime if you won't or can't and drive it over.  If you live upstairs, you're on your own :)
Amazon page with more info if you need it: http://www.amazon.com/Mitsubishi-WD-65732-...D/dp/B000GU4E1U
