The engine in my 99 is running a bit hot. The crappy OEM temp gauge doesn't budge. However, after driving for 30 minutes, the engine is radiating a ton of heat.
The radiator is the original (116,000 miles) as far as I know, so it's probably due for replacement anyway.
I replaced the thermostat with a generic from AutoZone. I hear the aftermarket ones are slightly different and not as good as the Mazda, but this was a stop-gap.
I replaced the radiator fluid with 70/30 mix, along with a new cap.
Neither change had any effect.
The fans are both running; I'm planning on checking the amps on the fans next.
Also, the water pump is not leaking, nor is it making any grinding noise. Anything else to look for regarding?
Anything else I'm missing?
:confused:
