5spd transmission output shaft.
		Long story short, bought the car about a week ago with a bad u-joint. Well it was worse than i thought. The whole joint had imploded in a matter of a few miles. Vibration went from just a bit to "the dash might come off" didnt drive it very far at all. Got a new prop shaft and seal. Pulled the old shaft and saw that a brass sleeve had come out of the end of the tail shaft. It surrounds the splines. It wont press back in all the way. Leaves about 1/8th still outside the housing. All gears shift smooth, no more vibration after shaft replacement, it does drive now just wont seal with brass sleeve out of place. Im thinking just replace the whole unit as its got 175,*** on the clock, plus i planed to do clutch, flywheel and PP anyway. I have (ok) pics but cant post them as im at work. Anyone know what im dealing with at the moment? Ill post pics asap.    Also if anyone knows where to get a good exploded view of the tail housing that would help.
Stock 1997 5spd
