1 Attachment(s)
		Rear windown defroster switch
		After reading loits of info on miata.net and elsewhere about typical rear defroster switch setups for NAs my 95 apparently isnt typical. Mine has fog lights and the switch for that apparently is in the spot where a typical NA would have the defrost switch, on the left side of the steering wheel where the cruise and light dimmer control is. Instead, the original owner installed some flat type of touch switch. See attachment. It doesnt really feel like you can push it. Almost like it would just sense body heat as you touched it in order to do the switching. Well, it is malfuntioning in that you have to really jack with it to turn it on and off. It isnt wired through the ignition meaning that it will turn on and off without the key even being on. My question is, does anyone know where I can buy a new switch like this?
Attachment 4776
