Clutch job, driveshaft, motor mounts
		Ok so i'm planning the clutch job i've been dreading for months, Were planning it in teh next two weeks. Buying some last minute things from rosenthal. Just need to make sure I've got all the random seals and whatever is good to replace while im down there. I've been searching but haven't come up with a complete list other than TO / pilot bearings, rear main.
Doing a clutch / fidanza flywheel, replacing driveshaft with junk yard piece, replacing shot to hell motor mounts with Mazdaspeed mounts.
So far i've got, full budget clutch kit form rosenthal, inc. pressure plate TO bearing, pilot bearing, allignment tool.
Flywheel with Fidanza's special threaded screws.
Rear main seal.
New shifter rod bushings, and the inner/outer boots.
Ordering now:
Transmission Front seal
Transmission rear seal
Gear oil, trans / diff.
New clutch / brake pedal rubber, the bare metal is scratching up my shoes.
^I'm assuming these are a good idea, but haven't seen them reccommended in the threads i've read. Also, is there a cheaper place to get these form, i.e Vatozone, oreileys?
Tools, between me and a buddy we should have everything covered. I'm heading to harbor freight for something for the Element this weekend, i'm going to pick up a seal puller if they have one cheap enough. If not i'll use a screwdriver.
Anything else would be a good idea while i'm replacing the motor mounts / drive shaft...anything i'm forgetting relating to the clutch?
