Water Pump Replacement went wrong :-(
1991 NA
Followed the tutorial on how to replaced the water pump. Took a while but got it in and started her up. Ran smooth and quiet. Temp heatd up and stayed in the normal range. Shut it off, freshened up a little and took a spin around the neighborhood. NO issues.
Drove up to the 7/11 to get a celebration beer. Came out, started it up and now there is a knocking sound that follows with the rpm's of the engine. Pulled all the timing covers and valve cover back off - did not look like the belt had slipped. Only the exhaust cam pulley bolt was a smidge loose. Tightened that - put it all back together and started it up.
Noise is still there...
Dang it!!!!
Can anyone help?
