Broken NB exterior door handle
		Ok, leave it to me to have all of the weird problems.
The drivers side exterior door handle on my 99 has recently started pulling loose from the door (the end towards the rear of the car) when I open it.  I figured I just had a retaining nut that had come loose so I pulled enough of the interior panel out to get a look at it.  From what I can tell, the door has two tabs (part of the door skin itself) that the handle bolts onto.  It looks like the tab at the rearward end has broken letting the handle rotate away from the door when you pull on it.  Both of the tabs are on the top side of the door handle assembly but I don’t see anything on the bottom side of the latch to keep it secured to the door (i.e. to prevent letting it rotate away from the door when you pull up on the handle).  It seems odd to me that the only two attachments would be on the top side of the door handle assembly.
Anyway, when I get home later today I’m going to see if I can remove the door handle assembly and I’ll post some pictures.  Just curious if anyone else has run into anything like this or know how it should attach to the door.   Also trying to figure out how to repair it.  I don’t think the tab can be welded back to the door without damaging the paint around the door handle.  If so, the only other thing I can think of is to make some kind of bracket that bolts to the back side of the handle assembly and has tabs that push against the inside of the door to hold it securely.  Anybody have any words of wisdom?
And I was silly enough to think all I had to do was tighten a nut….  :gaah:
