I have a pair of Kirkey Economy Drag Race seats for sale. I've had them for less than two years now and they have very little wear on them since my Miata is mainly my track car after buying a MS3. They are mounted onto OEM seat sliders and the seat widths are 15.5" (driver-side) 17.5" (passenger-side) and they have black nylon seat covers. They lower you considerably and I'm way below the HDHT roll bar that isinstalled in the car. I have enhanced the padding with high density foam for a little more comfort. The seats can easily be changed from side to side if needed. I went with the larger passenger seat width to accommodate a "wide" range of ::Bum::s.
These seats work great for the track and really make the car feel like a go-kart. They are still OK for a hour of two of highway cruising, but being a ::OldMan:: they've become a bitt too much for me to take. So I'm going back to my modified OEM seat with belt pass-throughs. I bought them from a local race shop and they are available for pick up in Flower Mound.
A perfect TCB alternative to other costly seats $350 for the pair - will not split them up.
Economy Race Seat Features:
This Kirkey seat features a 20° layback for a comfortable fit in your door slammer car. These Kirkey seats are made with .125'' thick 5052 grade aluminum, They are TIG welded and MIG welded inside for added strength. The high back design head rest is reinforced with Kirkey's unique tubular rolled edge. The seat bottom is contoured to support your lower back and hips. A rubber molding is added around the perimeter of the seat and the belt opening for safety. The Kirkey seat sides are lowered for lap belts, the Shoulder and Submarine belt opening is standard.
Kirkey Economy Drag Seat Covers have extra thick, high density foam padding on bottom to support thighs. The upholstery is double stitched around belt openings and all stress points.
