Last Friday, when I moved my car out of the shop to wash it, I noticed that the driver's side rear caliper was not releasing. I went back into the shop and removed the caliper and noticed that the 14mm plug bolt and 6mm Allen key adjustment bolt were missing from the caliper. I cleaned everything up, put high temp grease on the sliders and all seemed OK. Brakes seemed to work fine. So back to the washing and waxing.
Saturday morning I headed out to a car show, and the driver's side rear caliper was again stuck. After searching on the forum, I replaced the caliper with a Duralast from Auto Zone. When I installed it today I found that it did not have an adjustment screw under the plug bolt. Is this normal for the left side? There is one in the right side.
So far I have not been able to get the left parking brake to work. The right one works fine. Any hints or tricks?
Thanks in advance...
